SB50P starting problem
Posted: Mon Oct 03, 2011 9:46 am
by that1mopedguy
I have a 1989 sb50p. when i pull the brake lever and push the "start" button, it makes a noise that sounds like a trains horn but then starts up after a couple times. haha. is it because of the cold outside, or what? does anyone have any suggestions?
Re: SB50P starting problem
Posted: Mon Oct 03, 2011 1:17 pm
probably a dirty or dry (no lube) or bad starter bendix. Disassemble, clean, lube and try again. If not fixed, replace the bendix.
Posted: Tue Oct 04, 2011 12:01 am
by maddog
belt dust can cause this
Posted: Tue Oct 04, 2011 7:39 am
by that1mopedguy
over the winter, i'm gonna have my carburetor cleaned, replace my drive belt, ignition coil, tires, air filter, battery, and upjet my scooter. thanks for the suggestions.
