SB50P starting problem
that1mopedguy
Post by that1mopedguy »
I have a 1989 sb50p. when i pull the brake lever and push the "start" button, it makes a noise that sounds like a trains horn but then starts up after a couple times. haha. is it because of the cold outside, or what? does anyone have any suggestions?
Re: SB50P starting problem
probably a dirty or dry (no lube) or bad starter bendix. Disassemble, clean, lube and try again. If not fixed, replace the bendix.
maddog
Post by maddog »
belt dust can cause this :nerd:
that1mopedguy
over the winter, i'm gonna have my carburetor cleaned, replace my drive belt, ignition coil, tires, air filter, battery, and upjet my scooter. thanks for the suggestions.
