Spree Starts goes about a block and shuts down!!!!!
Posted: Mon Oct 06, 2008 7:35 pm
by e_kmiec23
Ok so I got a Spree that goes a block and then it just shuts off even at idle it goes for a min then same thing. Cleaned the carb and all any help would be great guys!!!
Posted: Mon Oct 06, 2008 8:11 pm
by devenex
Have you checked the fuel flow? Just quickly disconnect the fuel and vacuum lines (placing the fuel line's end into a jar) and suck on the vacuum line.
A steady stream of fuel should come out, otherwise you have a problem with a clogged fuel filter or crotchety petcock.
Posted: Mon Oct 06, 2008 9:15 pm
by Kenny_McCormic
Clean carb again check float operation.
