WOT sound: NEE NEE NEE NEE -- 2001 Elite SR
Posted: Mon Oct 06, 2008 1:39 pm
by bryanska
Hi - when I am cruising wide open on flat ground (35 MPH) I hear/feel an oscillation in the scooter. The motor kinda goes "NEE NEE NEE NEE" very subtly, as if I'm bouncing off a rev limiter.
It's not a hard bounce, and no power is lost. Mostly a difference in sound.
Normal? Not normal?
2001 Elite 50SR (SA50 I think)
2100 miles
Totally stock
Never de-carbon'd pipes or manifold
New NGK plug
Very slightly out-of-true front wheel after a crash (replaced front fork)
Posted: Mon Oct 06, 2008 3:24 pm
by burnt_toast
may have something to do with it.
otherwise if no power lost, I wouldn't worry about it. 35mph is right speed for stock S
Posted: Mon Oct 06, 2008 3:54 pm
by Kenny_McCormic
Plug chop
Posted: Tue Oct 07, 2008 9:44 am
by noiseguy
Don't all 2-strokes do that at WOT?
Posted: Tue Oct 07, 2008 4:10 pm
by Kenny_McCormic
noiseguy wrote:Don't all 2-strokes do that at WOT?
Not when tuned correctly. Should scream right along real smooth.
Posted: Tue Oct 07, 2008 5:58 pm
by SpyderMike
mine did that, then i cleaned the carb and now the "bounce" is gone
Posted: Tue Oct 07, 2008 6:00 pm
by SpyderMike
and my main jet was backed out 1.5-2 turns, so it was tight when i put it back together
dont know if that had anything to do w/ the noise, but that was the only problem i seen
Posted: Mon Oct 13, 2008 12:32 am
by wilsoniya
Is your plug properly gapped? My scoot cuts out at high RPMs unless I have a very tiny gap.. like 0.7mm or less.
Posted: Wed Oct 22, 2008 10:19 am
by EliteS120ccJDM
Probably the C.D.I ... change it to a racing C.D.I box..that's what I did..it takes of the rev limiter...so at top speed you won't hear that...and it throws more spark...so you'll probably top out at 36 or 37mph
Posted: Wed Oct 22, 2008 4:55 pm
by Dac
EliteS120ccJDM wrote:Probably the C.D.I ... change it to a racing C.D.I box..that's what I did..it takes of the rev limiter...so at top speed you won't hear that...and it throws more spark...so you'll probably top out at 36 or 37mph
your nuts. the stock CDI isnt rev limited at all. And the stock spark is already blue/white, you cant throw more spark.
