How to fix low MPG, checklist
The home of the FAQs and all the things you need to know to fix your Spree / Elite, outside the service manuals
Moderator: FAQ Moderator
Locked
Spree typically get around 100 MPG when in good operating condition. That works out to a 50 mile range on a tank of gas. If you're not getting that:
1) Check the air filter to see if it's clean/installed/not over-oiled.
2) Check exhaust and exhaust port for carbon
3) Check plug wire and plug. Plug should have a nice blue spark, red means poor plug or wire to plug cap connection
4) Check compression. Should be around 110 - 115. Below 100 means rebuild time. Better compression = better efficiency
5) Check the needle jet, should be set 4th notch from the top.
6) Check carb main jet, should be a #65 or #68
On a good running scooter, checking the carb (5 & 6) should cover it.
Locked
