2000 Elite SA50 SR - what first mod to go faster?
I have a 2000 Elite SA50 SR with about 3000 miles.
It is stock and tops out at 35MPH.
What mods do I need to do to get it to 45MPH top speed?
Will drilling out two baffles in the muffler help acceleration?
2000 Elite SA50
stock
stock
Get yourself 9.1 gears and a highspeed pulley from vtcycles (808-593-7733) which will come out to like $105 shipped..should hit 45-50 mph occassionally a little fast depending on how strong the wind is to your back
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
average 85 mpg
Easy work..to change put on the hs variator just take of the cover on the left side of the bike, use an impact gun to take of the front clutch(aka variator) take it off put the new one on and do everything in reverse order
As for the gears its easy..you just need a press to take off the old gear and put on the new one:
http://hondaspree.net/phpBB2/viewtopic.php?t=4489
Honda Elite SA50-S
average 85 mpg
average 85 mpg
impact gun is kinda needed.94cruiser wrote:can I use a cheater bar?
I don't have an impact gun.
i have heard of people putting a open end 10mm wrench, shoved in there to hold the flywheel in place while you use a cheater bar.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
junkyspree
- BMX
2 possibilities. Like Kenny said Harbor Freight is a good source. They often have their 12V impact wrench on sale for about $20. Just hook it to a car battery or even your bike battery. Then you can carry it in your car in case you ever need to do a wheel change!
The other thing you can do is build a simple tool from 2 pieces of steel bar as described here:
http://www3.telus.net/dougsimpson/Elite_1.html
Works on a lot of different scooters.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
