Problem with my 87'
Problem with my 87'
I got a problem with my scooter , went i lift my rear wheel and i give gaz a dont have problem , but want i put on the floor and i try to run , the motor stop after 20 or 30 feets ...
What is the problem ?
- chevyguyjay
I make a compression test and everything look ok , a clean the carburator and i shoot a lot of carburator cleaner after the be sure ... and the air filter is clean ... i think is a problem with the gaz valve.chevyguyjay wrote:throw a compression tester on there and c what u have. also, pull the carb apart. air filter could be dirty to.![]()
Very helpful comments ...Kenny_McCormic wrote:1. use english
2. i dont know
Re: Problem with my 87'
Parlez-vous Francais?HondaSE50 wrote:I got a problem with my scooter , went i lift my rear wheel and i give gaz a dont have problem , but want i put on the floor and i try to run , the motor stop after 20 or 30 feets ...
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Oui , je parle fran├â┬ºais et je suis du Qu├â┬®bec plus pr├â┬®cisement Montr├â┬®al !Clivester wrote:Parlez-vous Francais?HondaSE50 wrote:I got a problem with my scooter , went i lift my rear wheel and i give gaz a dont have problem , but want i put on the floor and i try to run , the motor stop after 20 or 30 feets ...
dukemartini
stealth SE
Sorry sounded like ghetto to me and not a french guy trying to use English.
HondaSE50:I would recommend you get a copy of the Mozilla Firefox web browser, it has a built in spell checker so you wont spell gas "gaz".
I would try cleaning the carb.
Did you remove the small brass cartridge under the main jet and clean it out?http://www.hondaspree.net/phpBB2/viewtopic.php?t=5389 just blowing it out works but you will never get all the gunk out without removing it.
