vermi
Posts: 13 Joined: Mon Jul 23, 1973 10:24 am
Post
by vermi » Mon May 09, 2005 9:55 pm
Hello,
The crankshaft of my second Spree is bent. I need to replace.
Is it possible to repare the crankshaf?
darat
Posts: 3132 Joined: Fri Jul 23, 2004 10:24 am
Post
by darat » Mon May 09, 2005 10:14 pm
not that i know of
vette76
Posts: 1830 Joined: Sat Jul 31, 2004 8:00 pm
Post
by vette76 » Mon May 09, 2005 11:12 pm
no u definately want to replace that. parts like that are so precise u should just replace that instead of really doing some damage.
87' spree (SOLD
12' wrx
vette76
Post
by vette76 » Mon May 09, 2005 11:13 pm
contact
drichardson@core.com he will have it (used) but better then what u have now.cheap too.
87' spree (SOLD
12' wrx
Posts: 4385 Joined: Sat Jul 31, 2004 8:00 pm
Post
by noiseguy » Tue May 10, 2005 9:12 am
Find a machine shop that will take a look at it and ask them if it can be repaired. You would need a 20 ton press and dial guages to do this yourself.
What I expect that you'll find is that it's cheaper to buy a used part from Richardson or off the internet than it would be to have someone true it.
BluPhire
Posts: 390 Joined: Sat Jul 31, 2004 8:00 pm
Post
by BluPhire » Wed May 11, 2005 11:17 am
ya. ya. ya. that's great. thx Vette and noise, but HOW THE * DID YOU BEND IT?
I try to fix things with a hammer and wrench!
Post
by noiseguy » Wed May 11, 2005 3:24 pm
You know, you may be able to fix this with hand tools. If the counterweight halves are bent inward, you can bend it back out with a prybar. If they're bent outward, you could squish them back together in a vice. I've seen this repair description in a moped manual somewhere.
If it's bent torsionally, if the counterweight halves don't line up as you scope down the shaft, you might be able to fix it by using the vice to realign them. This I'm not as sure about.
You'd still need a set of V-blocks and a dial micrometer, but you should be able to do this w/o the press.
Or is just the fan end bent? That's what it looks like in the pics.
