Quick fix for more RPM?
RastaCalavera
Post by RastaCalavera »
I have an 87 honda elite 50 that tops out at 22mph. It is a stock set up and I had the carb cleaned last summer. The belt is fine and in good condition, so what can I do to get more bang for my buck? I was talking to some friends and they were saying that if I got a cone shaped air intake instead of the stock rectangle I have, that would help out, but can I do that with out off setting the plastic body? I'm not too great with engine mods or what not so if that could be avoided, that would be best. oh is there a governor on these things?? How do I take it off if there is? One guy said there might be a computer box somewhere on the bike, but unless it is hidden under the speedometer I've never seen it. I don't think there would be any computer chip on something this old as well. Any help is good help. Thanks!
chevyguyjay
Post by chevyguyjay »
Does your elite have a high speed variator on it or is it the stock one?
~2004 Geely Fashion~
RastaCalavera
stock. I haven't done anything to the bike itself execpt clean the carb
jstone
Post by jstone »
I don't know much about elites so Dac needs to help you, but isn't there a washer in the exhaust that restricts flow and also a plate on the variator? Both of those needs to be removed to "derestrict" your scoot.
RastaCalavera
is there a walk through anywhere on how to do that? i don't know much about the engine and don't want to mess anything up
jstone
Post by jstone »
I don't see one and i personally have no idea, having never worked on an elite before. Wait till Dac sees this post, he can run you through it i'm sure.
dukemartini
Post by dukemartini »
http://www.hondaspree.net/phpBB2/viewtopic.php?t=1259
also 22 mph might mean you have an Iowa model the most restricted of the bunch.
i'm not really sure what those restrictions are however. use the search feature.
87 Honda Elite S-BASKET CASE PROJECT
88 Honda SB50P-sold but not forgotten
Don't use a pod filter. That's not going to help. Neither is the computer.
22MPH is too slow... you need to look at the basics to fix this. Compression, plug condition, exhaust / exhaust port carboning up, head carboned up. If this Elite has a variator (it sounds like it does) you may want to check the rollers as well.
RastaCalavera
Thanx for the input. I checked the web site for VTCYCLE and a lot of the parts they dont carry anymore but they do have a high speed pully kit with 9g rollers, i don't know if that would work. Hmm an iowa engine you say? Why would they restric those? There is nothing down there anyway hahaha. What basics could I do to see if I could clear anything up? I kind of cleaned out the outside, got a new air filter and cleaned the carb, my belt is fine so the onlything I could think of is if you guys want me to clean up internal parts or something. . . .
dukemartini
noiseguy wrote:Don't use a pod filter. That's not going to help. Neither is the computer.
Theses are the internal parts that probably need cleaning. If the last owner used crappy oil there will be carbon buildup everywhere, the oil was. I have seen pictures of exhaust ports totally blocked with carbon. These are the most likely suspects for this problem. Good luck!
