1994 Honda Elite-Will not start in the morning.
khs1991
Post by khs1991 »
:( I have a 1994 Honda Elite. It will not start in the morning, it has been around 35-40 degree's. It will turn over fine and maybe idle for a short time and then die. I went home after work yesterday and it started right up and ran pretty good, with a little carb. adjustment. Are these cold blooded, or do i have a problem?
Dac
Post by Dac »
they are kinda cold blooded. but there not that bad.
i was able to start mine when it was 20*F and ride in the winter. But it was rather hard.
Im not sure what type of air filter you have. but try blocking some of the opening when starting it. It might help out.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
khs1991
elite
Post by khs1991 »
i have a stock air cleaner that came with it. i cleaned it and put it back on. it is stored in a metal shed and it is pretty cold in there in the mornings. let me know if you have any other idea's.
thanks
steve
berreta22
Post by berreta22 »
Mine is a pain in the mornings, so what i usually do is take off the intake tube from carb to air cleaner and put 2 fingers over it to start it then usually one finger just enough to keep it running for about a min. Then pop the tube back on and let it warm up and off you go.
Post by Kenny_McCormic »
berreta22 wrote:Mine is a pain in the mornings, so what i usually do is take off the intake tube from carb to air cleaner and put 2 fingers over it to start it then usually one finger just enough to keep it running for about a min. Then pop the tube back on and let it warm up and off you go.
If im having choke problems i find it easier to reach under the body panel and plug off the airbox breather holes.
berreta22
Post by berreta22 »
why didnt i think of that?
stillspeeding
Post by stillspeeding »
i have all manual chokes=instant starts.
Can't afford speed then stay away from it!
Dac
Post by Dac »
stillspeeding wrote:i have all manual chokes=instant starts.
yeah but he has the stock carb. So he don't have a manual choke.
My auto choke=running on the first kick(assuming the semi functional kick starter engages).
stillspeeding
run a clear fuel line, if its empty in the morning then you have a bad fuel valve.
