Do these cdi increase speed as advertised on Elite 50
uksailmaker
Post by uksailmaker »
I just picked up a 1998 not running....2 questions
1-- I know after years of not running I will have a carb problem...I was thinking about a aftermarket new carb....or how do I clean the carb
2-- do these cdi increase power
thanks
stillspeeding
Post by stillspeeding »
If its stock just derestrict it, all the hi-po stuff is for the serious builders, before i change a cdi i change the coil-MSD street blaster :lol:
Can't afford speed then stay away from it!
Dac
Post by Dac »
after market carbs are fun but cost around 160$ and unless you plain on putting on a bore kit its rather useless.
the CDI box on hondas are unrestricted. those ebay boxes are a scam. Unless you have really high powered coil.
derestrict itonce you get it running, your top speed and take off will be way different along with your over all power.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
stillspeeding
Clean the fuel tank real good before you try to start the engine, bacteria lives in fuel, use a flashlight and you will see it floating, i use a turkey baster to suck it up.
tru72
Post by tru72 »
actually those cdi boxes are not scams.. they do increase your rev, but advances the timing a little bit. Which makes your bike run hotter. I have a friend who makes those in taiwan..
stillspeeding
For a stock engine it will do nothing and never buy a taiwan coil as they are worthless! factory coils put out more voltage :lol:
