Engine stalling when riding. Please Help!!
Posted: Sun Sep 09, 2007 3:46 pm
by teepee848
Hi guys, i need help with my 1986 Spree. The engine runs fine and sounds smooth when it is on the kickstand (full throttle). But when i take it off the stand to ride it, the engine bogs, then stalls.
Posted: Sun Sep 09, 2007 8:28 pm
by No_Stopping_A_Spree
clean the carb really good
Posted: Sun Sep 09, 2007 8:41 pm
by joeweir1
Man, does this sound familar! Seems to be a common problem.Mine did the same thing and I replaced the reed valves and gaskets and it cured my problem.I went thru the scooter so many times till I deciced to replace them.Also, spray carb cleaner or starting fluid around the carb and reed gaskets while it is running and see if it changes how it runs.Could be just leaking gaskets onthe reed valve assy or bad reeds.good luck
Posted: Mon Sep 10, 2007 5:02 pm
by teepee848
I will try both solutions & let you know the outcome.
Thanks for your help
Posted: Mon Sep 10, 2007 8:03 pm
by tru72
haha joe you beat me to it!
aloha
D
