Help spree wont start
Posted: Tue Jun 05, 2007 3:36 pm
by cannon3731
Heys Guys i need some help.
I got a spree from a guy who said it has not run in years. I checked the compression and it was 60 psi. I then got some gaskets and rings and did a top end job. Compression is grate now and has great spark but i cant get it to start. I have cleaned the carb 3 times. I have put gas a little gas down the spark plug hole and have tryed starting fluid but i cant get it started. Any ideas
Thanks
Posted: Tue Jun 05, 2007 4:02 pm
by Kenny_McCormic
did you clean the muffler? try dumping some gas down the intake instead. ifyou havent alredy try a new sparkplug even if the current one looks good
Posted: Tue Jun 05, 2007 5:41 pm
by chevyguyjay
put a little engine oil in the spark plug hole. this should bump up your compression to get your engine to fire. also, smother your carb with your hand while tring to start it. once u get a little gas on your hand, take your hand away. thats manualy choking your carb.
Posted: Tue Jun 05, 2007 5:44 pm
by Kenny_McCormic
chevyguyjay wrote:put a little engine oil in the spark plug hole. this should bump up your compression to get your engine to fire. also, smother your carb with your hand while tring to start it. once u get a little gas on your hand, take your hand away. thats manualy choking your carb.
good idea the engine probably needs help to run before it braks in
Posted: Wed Jun 06, 2007 12:40 am
by cannon3731
I tryed a new spark plug , put my hand over the carb, put gas in the intake and still no start.
Any other ideas
thanks
Posted: Thu Jun 14, 2007 5:42 pm
by spree nut
What year is it?
Posted: Thu Jun 14, 2007 7:36 pm
by Kenny_McCormic
oil in the plughole
Posted: Mon Jun 18, 2007 12:47 pm
by Spreewell
Turn the key to the run position and quit huffing in the gas tank.
Posted: Mon Jun 18, 2007 2:43 pm
by Kenny_McCormic
Spreewell wrote:Turn the key to the run position and quit huffing in the gas tank.
