af05e bbk carb question
afo5e bbk build with stock stroke crank and malossi 70cc bbk and Leo vince sp3 and ct intake and a 21mm polini pwk carb and at 800' elevation, what is an input for a good jetting starting point for this carb and setup?
Re: af05e bbk carb question
Burnt Toast is the af05 wizard. See if he replies. I messed with one years ago, got frustrated and scored an af16. Never looked back. Good luck.
okay and thank you
The Polini (and Malossi...) 47 mm cylinders yield 65cc, not 70. Neither revs high enough without porting to justify a 21mm Carb. 17.5 or 19 is plenty. Amal/Arreche made direct-fit carbs if you still have the stock intake. Otherwise you'll install the Adapter kit from Swap-Shop and I encourage you to consider the 19 mm Polini. Tuning will be a LOT easier.
I did a 21mm before I seen your feedback and its an after market intake and reed block, still having issues dialing in jetting and where needle needs to be
