1987 spree
will
1987 spree
Post by will »
I had mine parked for a year due to a tire blow out. fixed tire and the carb was gummed up.
ordered one off amazon bolted up and put fresh gas in cleaned plug off. its getting spark and fuel but pops when kick started a little bit but wont fire.
any help greatly would help.
Re: 1987 spree
Your troubles will all disappear if you clean the OEM and toss the Chinese junk.
will
Re: 1987 spree
Post by will »
oem slide is to froze up and pited to use
Re: 1987 spree
Best put a new spark plug in it.
Too bad about the neglected carburetor getting
ruined. Check the muffler to see if oil has drained down and filled it.
Might want to change the fuel lines to new if they are the OEM's.
