Oil on spark plug
Oil on spark plug
Trying to bring spree back to life. I can get it to run for a few seconds if I shoot gas through spark plug hole. I then pull plug and it has oil filling the gap. On a different bike, I had the oil pump leak and fill the crank case. I am wondering if I have the same issue here. I have cranked it with exhaust off and plug out. Got some oil out. Now has stopped spraying. Is there an easy way to "drain" the crankcase?
