does honda vision mini/pre 86 spree have a vacuum line?
Posted: Mon Nov 30, 2020 7:37 pm
by stratokast
I recently got a vision mini and I know that they are similar to the spree but it doesn't have a vacuum-operated petcock. and I just bought this carb
https://www.pedparts.co.uk/product/5370 ... -minarelli and it has a vac inlet so basically, my question is can I use this carb without the line from the carb going anywhere?
thanks.
Re: does honda vision mini/pre 86 spree have a vacuum line?
Posted: Mon Nov 30, 2020 9:36 pm
by bonesv
Plug the vac inlet barb by capping it off. You do not want air entering there.
Posted: Mon Nov 30, 2020 10:07 pm
Yes, you can use it, but not going to be easy to engage the choke with body panels in place.
