Looking for the above info..also stock jet size for carb
Thanks!
2000 Elite 50 Stock variator Roller size and weight?
2001 Elite SA50P
Polini Contessa
YMS V8 pipe
Malossi Fly clutch x/TFC bell
NYC 1000 RPM contra spring
Polini variator 5.9 Polini rollers
9:8:1 gears
Stock carb 90 jet
Polini Contessa
YMS V8 pipe
9:8:1 gears
Stock carb 90 jet
Re: 2000 Elite 50 Stock variator Roller size and weight?
The roller weight size is 13x16 and I'm pretty sure the stock weight is 9 grams.Jaygen wrote: Tue Jun 11, 2019 1:02 pm Looking for the above info..also stock jet size for carb
Thanks!
The somewhat restricted sa50p model has a #68 main jet and the carb is stamped 35K --- on the flange.
The unrestricted sa50 model has a #78 main jet and the carb is stamped 35J --- on the flange.
- vintagegarage
What bonesv said.. and both the original roller weights and the #78 main jet are still available from Honda for cheap..if you want to stay with the original weight and size, please buy from Honda..
Thanks guys!
2001 Elite SA50P
Polini Contessa
YMS V8 pipe
9:8:1 gears
Stock carb 90 jet
Polini Contessa
YMS V8 pipe
9:8:1 gears
Stock carb 90 jet
