Tubeless elite wheels
Posted: Fri Jan 05, 2018 12:29 am
by 52much
I dismounted a tire from an elite wheel today and it didn't have a tube. Has anyone ever tried this with elite wheels?
Re: Tubeless elite wheels
Posted: Fri Jan 05, 2018 1:54 am
by Dallen70
Yes itÔÇÖs works great
Posted: Fri Jan 05, 2018 4:51 pm
by Rancher1
The Elite rim isn't designed for tubeless. YMMV but I wouldn't run it like that. The safe route for tubeless is to swap in a Metropolitan wheel.
Posted: Sat Jan 06, 2018 6:38 am
by 52much
does anyone know the difference in design for a tubeless wheel and a tube type? I know metro are wider. It must have something to do with how the tire seals.
Posted: Sat Jan 06, 2018 12:37 pm
by Rancher1
Yes, the rim lips are slightly different. TheyÔÇÖre designed to better seal against the tire. People have run tubeless with tube wheels/tires without problems. Personally I wouldnÔÇÖt do it, especially with the speeds our modified bikes reach.
Posted: Mon Jan 08, 2018 9:11 pm
by bonesv
Yea, the met wheel is the way to go for tubeless tire. The steel is heavier gauge and the taller bead area is also wider (2.15") than the elites' 1.85" so you are able to run a 90/90/10 without worry of clearance. Only metropolitan wheels 2003-2011 will fit. I believe the later model wheels (2013 & up) are larger diameter brake drum and will not fit. I just installed a new set of 3.00/10 IRC tires on elite wheels and they were so stiff and flat (4 yrs old) I put the tubes inside of them and inflated a little, then placed them in a 200 degree oven for 15 minutes to avoid damaging the elite's thin wheel/bead. Of course I wore some gloves to handle them and they went on like a dream.
But I would not run any elite wheel with a tubeless tire especially over 35 mph.
Posted: Fri Apr 13, 2018 12:43 am
by micbergsma
Rancher1 wrote:The Elite rim isn't designed for tubeless. YMMV but I wouldn't run it like that. The safe route for tubeless is to swap in a Metropolitan wheel.
Yup that's what I did..... switched to Metropolitan wheel and it's awesome!
