Page 1 of 3
Re: Dio disc brake front on Elite frame
Posted: Sun Mar 08, 2015 12:34 am
by bonesv
EDIT: Some of this post is missing from the beginning so I will try to replace it as best as I can but you can get any headset to fit on any other scooter frame as long as you are willing to take some risks, make a fearless effort, and do some real involving work with a variety of tools and machinery._____First, I went online to the yahoo japan auction site and purchased a nice condition dio af28 headset and complete front disc brake setup which included the handlebars, speedometer cowl and the wiring and headlight stem, wheels, and all the hydraulic brake system. Then I measured how much the difference was between the two scooters frame, neck and stem and calculated that if I took a 3" section out of the top of the neck on my sa50 Elite scooter and welded the top section back on like it shows in this first pic, it could fit and clear the front cover, and if I cut some of the fender underneath where the stem would have to clear the turning radius, it might work with some finessing and heating up and bending the plastic. Then cut the top for correct size of metro stem and install bearing cup.
IMAG0850 - Copy.jpg (43.87 KiB) Viewed 38886 times
Before moving on, the metro uses a larger bearing on the bottom than the elite, so remove the lower bearing race from the metro stem carefully and replace it with a new (you have to order one from honda) elite lower stem race. It's a press fit so make sure it's all the way on. Right here I want to mention that you can get a stem from a dio with disc brakes and use that instead but it has to be a disc brake sized stem. A drum brake stem is not wide enough to make into disc brake so be sure it's for disc brake! Next, remove some of the material from the stops if you use the metro stem, to suit your steering desires.
IMAG0859 copy.jpg (64.7 KiB) Viewed 38886 times
IMAG0862 copy.jpg (69.39 KiB) Viewed 38886 times
With the use of the af28 handlebars, and cutting the neck off of the elite, I foolishly lost the use of the key switch/locking mechanism, but you can cut around and leave the key switch mount bracket.
Posted: Sun Mar 08, 2015 12:35 am
by bonesv
Assemble parts...
IMAG0856 copy.jpg (56.98 KiB) Viewed 38882 times
Add the fender to estimate clearance
IMAG0864 copy.jpg (50.51 KiB) Viewed 38882 times
Use heat gun to make clearance for turning radius....then install inner floor /glovebox to check fitment. Mocking-up the parts is crucial for correct look/fit. Install headset for fitment.
IMAG0884 copy.jpg (44.99 KiB) Viewed 38882 times
Stay tuned for more.....
by bonesv
Once everything is to your liking, you must first swap-out the plug-ins for the speedometer to fit the elite. Just cut and splice....easy. Then, prepare to install the dash, throttle cable, disc brake reservoir/lever, rear brake cable......
IMAG0889 copy.jpg (49.75 KiB) Viewed 38881 times
IMAG0896 copy.jpg (61.35 KiB) Viewed 38881 times
Keep in mind, this is just a mock-up for a customer. I would never do this on my own scooter!!! Well, maybe......ooops! Daylight savings time just kicked in, I better get some sleep...
Posted: Sun Mar 08, 2015 12:36 am
by bonesv
Putting it together..... install the Dio legs.....
IMAG0916 copy.jpg (69 KiB) Viewed 38851 times
finish up headset and dash......install Dio wheels/brakes and front/rear plastics
IMAG0920 copy.jpg (61.12 KiB) Viewed 38851 times
Now as you know, we must test ride it into the sunset!
IMAG0921 copy.jpg (48.19 KiB) Viewed 38851 times
Posted: Sun Mar 08, 2015 12:37 am
by bonesv
WOW! What a nice ride with this front end! I'm pleased with the handling and ride. Maybe some shorter legs would help the elite's profile but all-in-all, the feel of the road is great!
IMAG0923 copy.jpg (46.55 KiB) Viewed 38851 times
I just may do this to my own ride some day! Going to give him a bid to paint up the gray faded plastic and trim, etc... Definitely liking the look of this scooter now! I will get some more pics when it's finished complete. Thanks for looking and if you need any info I may be able to give, just pm me.
Posted: Sun Mar 08, 2015 1:18 am
by bonesv
So I have re-painted the faded gray plastics with some nice bumper coating from the local auto parts store, and got some cheap but cool looking mirrors to help it out, then re-covered his seat for him.
Go ahead, shoot us some comments.....I already know it would look better if it was slammed but he don't want that.
3-2015 011 copy.jpg (52.61 KiB) Viewed 38757 times
3-2015 012 copy.jpg (50.38 KiB) Viewed 38757 times
3-2015 010 copy.jpg (57.69 KiB) Viewed 38757 times
Posted: Mon Mar 09, 2015 12:52 am
by bonesv
I had seen some pics of guys in Hawaii with the Dio headset on an elite and thus it inspired me to try this. I also want to thank Paul and Brandon for their contributions to my imagination. I couldn't have thought of this all on my own....But actually it was way easier than I had first thought.
Also, many thanks to hondaspree.net for this awesome forum and the experience of the members here.
Bones
Posted: Mon Mar 09, 2015 8:51 am
by swimmingfree
that is slick way of doing it ...
Posted: Mon Mar 09, 2015 10:54 pm
by kauaianman
bonesv wrote:Then cut the top for correct size of metro stem and install bearing cup.
Before moving on, the metro uses a larger bearing on the bottom than the elite, so remove the lower bearing race from the metro stem carefully and replace it with a new (you have to order one from honda) elite lower stem race. It's a press fit so make sure it's all the way on. Next, remove some of the material from the stops on the metro stem to suit your steering desires.
With the use of the af28 handlebars, and cutting the neck off of the elite, you will lose the use of the key switch/locking mechanisim. Yes, to do this you must source a complete Dio-from-Japan-front-end. Always liked the look so I did some bidding and not so bad. Stay tuned for more, it's almost finished!
Bidding? what site did you find that superdio headset and handlebar?
:happy:
Posted: Mon Mar 09, 2015 11:36 pm
by bonesv
:happy:
Ahhh. You hear very well......Got them from a member here on the forum about a year ago.
Are you looking for one?
Posted: Sat Mar 21, 2015 12:59 am
by bonesv
I have added some more pics of the finished job. Scroll back from here a bit.
Posted: Sat Mar 21, 2015 2:10 am
by Rip_City_Spree
Sweet looking elite.
Posted: Sat Mar 21, 2015 9:18 am
by 1man8scoots
I need to drop off one of my elites to you, if I started riding it now to you I'll be there by summer. Nice fab work bones!
Posted: Tue Mar 24, 2015 11:35 am
by Mini_Stroker305
Nice bike love the dio headset and front disc brakes :love:
Posted: Tue Mar 24, 2015 2:03 pm
by ped
Very nice work bonesv. :thumbwink:
