..along with the fan shroud.
only going around 35-40
just installed new bbk along with zxtrans kit / new belt and 9:1 gears on af16-swaped spree
still on first tank / breaking in and haven't given it WOT
if I remember correctly I heard a fast high pitched sound or maybe a ringing noise right before it happened but I could be wrong
has this happened to anyone before or know what may of caused this?
thanks in advance
Cooling Fan Exploded
gperspective
Pocket Change . Scooter Club
Honda Spree . AF16E
Polini Corsa - Naraku Intake - Dellorto 21mm PHBG - Malossi E8 AirFilter - Malossi Variator 7g - ZX Trans - 9:1 - PG Short
Honda Spree . AF16E
Re: Cooling Fan Exploded
Stock fan?
- paulpauly7
Aftermarket fans do this .
gperspective
yes, stock fan
Honda Spree . AF16E
Honda Spree . AF16E
Hmm I've heard of the aftermarket fans doing this but not the stockers. Maybe one of your bolts came loose I'm sure that could make for a pretty short lived fan. I would check for a striped hole or something.
gperspective
ah yeah
i was missing a bolt on the other piece of fan shroud - not the one that got torn up along with the cooling fan / encases the coolfan + most of the bbk
so i suspect it found its way to the fan somehow
bummer
i'll do some inspection and make sure it isn't still around
new oem part shroud + fan on order from partzilla
bummer
Honda Spree . AF16E
Honda Spree . AF16E
gperspective
also i imagine maybe a bolt from the main fan shroud may of rattled out
plenty of vibration with the higher rpms on this new bbk most likely
Honda Spree . AF16E
Honda Spree . AF16E
