Honda Spree Underpowered after carb rebuild.
Posted: Mon Aug 04, 2014 1:03 pm
Hi! Long time lurker, first time poster! I have 2 honda sprees. New to mechanical tinkering...
One of my sprees works beautifully, it hesitates a bit when it is cold, but for the most part its very reliable and starts right up everyday, and gets up to about 26-27mph with me on it (260lb;) and has pleanty of power to keep up with college town traffic.
The second one is the project bike, I bought it not running, it had been siting for 1-2 years, and looked really clean... 4k original miles.
1. The throttle cable was seized. replaces it.
2. The spark plugged looked like *.. dark brown and LOTS of build up grime. replaced that.
3. Pulled the carb. cleaned it (didn't find and magical white lights but later it seems to work anyway)
4. Replaced the Auto choke.
5. Made sure the pet * was working with vacuum.
6. Air box lid had a hole on the edge (melted?!?) used duct tape to patch it up... it seems to be working as i can choke the engine by covering the intake... (working on ordering a new filter and new airbox lid)
7. Replaced battery (though riding the scoot doesn't seem to recharge it)
8. Reinstalled carb
9. Got the scoot started... it kicked of a lot of white smoke from the tail pipe.. but that is probably oil that is burning off and is slowly dissipating.
10. Tuned the carb as best i can... (set idle a little high then adjusted the air screw till wheel stopped) It is bogging down the way my vespa does, or hesitating when the throttle is open...
Now the problems: The revs don't seem to get very high...even at full throttle, and the top speed is about 22-23pm, it is also under powered, and takes a long time to get started from a stop position and takes forever to get up to speed...
I guess the previous owner could have run it without oil and * up the cylinder/piston (hence the gross spark plug)... I assume i should check the compression... I will take it in to a mechanic to ask him to check it... what is a normal reading? do i need to drop the whole engine to replace the cylinder head/piston head? I want to avoid taking off the shock as i don't want to have to buy a spring compressor...
I will post video later...
8. Reinstalled carb
