starts 1st kick but not with starter??????
Posted: Sun Aug 03, 2014 2:36 am
by kauaianman
stock motor 49cc
stock everything
key on + 1 kick = start right up
key on + brake on + starter = eerrrrrerrrrrrerrrrrreeerrrrrrreeeerrrrrrrrrr.
not enough spark with battery pushing starter i guessing.
possibly old battery? not the electrical expert any advise good!
Re: starts 1st kick but not with starter??????
Posted: Fri Aug 22, 2014 6:37 am
by birdman
Faulty starter clutch.
Posted: Fri Aug 22, 2014 7:40 am
by swimmingfree
do a compression test .. useing the starter you need about 90 psi to start ....
Posted: Fri Aug 22, 2014 11:34 am
by birdman
If it starts on the first kick your compression is ok. Im almost 100% sure its the starter clutch losing its grip.
Posted: Fri Aug 22, 2014 12:20 pm
by swimmingfree
when kicking over the motor it move faster and dose not let as munch leak around the rings.... giving you more compression then with the starter... you cood have 90 psi kicking it and 80 with the starter...
Posted: Fri Aug 22, 2014 6:58 pm
by birdman
@kauaianman
faulty starter clutch is the safe bet. If it starts and runs fine with the kick start... low compression is not the issue. Compression reading will be the same wether you use the kick lever or the starter (5 revolutions is 5 revolutions no matter how u slice it). I would say his 10psi difference could be chalked up to a weak starter or starter clutch that gave him one or two revoltions compared to his kickstarter when performing the compression test.
Posted: Sat Aug 23, 2014 9:49 am
by Trafficjamz
the battery is probably too weak to spin the motor fast enough to start it.or the starter motor is worn out and can't spin the motor fast enough.
I would jump it to a car battery and see if it makes a difference.
Posted: Sun Aug 24, 2014 1:08 pm
by speedy25
Also an almost 30 year old starter was near the end of its life 15 years ago.
Good starter + good battery = easy starts
-SP
