Steering wobble
Mustang Man
Steering wobble
There is quite a wobble in the steering on my 85 Gyro. There doesn't seem to be any free play in the bearing so I don't think the nut is too loose. Is this normal or is there something I should check to correct the wobble?
Re: Steering wobble
IDK - check the front forks and rim. I've had on TG50's with rim and tire related wobbles. Bent rear hubs have set up a wobble too.
Re: Steering wobble
There is a lot of slop in the forks of most 50cc bikes.
The primary cause of wobble is tire condition.
Check to see if tire is fully seated on the wheel rim.
The wheel could have some warp.
Check the steering head bearings too.
If the tire is old, expect some wobble.
Re: Steering wobble
+1 to all the above and some more:
Twisted forks and general misalignment can be a cause.
I've seen chunked belts that felt alot like an out of balance wheel as well.
84 Aero125 Goldie, For Sale, parts bikes too
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
