up to how many cc can a injecter still be uesd
MySpree
Post by MySpree »
i do NOT want to mix gas, scrach that, WILL NOT mix gas and i was wondering, can i still use the oil injecter on my elite at full if i have a corsa kit, a pg long, a 28mm carb, and all that stuff?
darat
Post by darat »
well dude i would say yes and no i would put some of ur bell ray in mixed with the gas and still use the oiler to. i did that untill mine broke in and it ran fine.so i would do both
Why would you run a 28mm carb on that kit, isn't it a 75cc kit or so? That's too much air.
If you're running that big of a carb, you'll need to premix. HI guys have said in past that anything under 75cc with stock-ish carb sizes can be run with the stock oiler run wide open.
MySpree
Post by MySpree »
its 72, and noise its a carsa kit !!!! and sry its a 25mm carb,
maddog
Post by maddog »
76cc is the max for the injector with the correct gear ratio, myspree your gears are only for a derestricted engine- you need to "MAKE UP YOUR MIND" and build it right, wheelie popping is for kids!!!!
darat
Post by darat »
him pop a wheelie ha it has no power to do that..
MySpree
Post by MySpree »
im afrade to mess up my leet, and dude check ur pms maddog, so witht he 72 corsa kit i can use the injecter...
ashymonster
Post by ashymonster »
by disable do you mean to remove the injector entirely? Or just disable it and leave it connected? If I leave it on, do I leave it Open, Closed, in the middle?
"It's more fun to go fast on something slow than it is to go slow on something fast."
ashymonster
Right I get it now, read in another post. Plug it or grind the gears. LOL
MySpree
Post by MySpree »
yea well, im understandidn that with a corsa kit i can use the injecter... thanks
burnt_toast
Post by burnt_toast »
MySpree wrote:yea well, im understandidn that with a corsa kit i can use the injecter... thanks
dont risk it, go all premix. its safer solution.
I've been having over oiling issues on my stock zip injector which wasnt good for my stroker setup, now completely rebuilt im doing premix. it can be a pain but you'll be sure your getting the right ratio in there.
maybe the elite has a more solid injector setup, but thats up to you.
projects galore :nerd:
darat
Post by darat »
s*** with my elite i didnt have to pre mix
maddog
Post by maddog »
The pump can handle it but i never did with 9 to 1 gears which is for stock derestricted engines, oil pumps will last 50k before they smoke out the hood on a cold start and my 28mm carb still runs lean!
85stroka
Post by 85stroka »
I seen strokers --102cc run the pump,they modded the pump for more output,
