Jug, crank case not same year I suspect.
Posted: Mon Mar 18, 2013 11:57 pm
by jeepmaned
Not sure what is going on, I suspect someone put on a later model or another model jug. Trying to re-ring and wondering what I have here.
I ordered honda part 12191-gs7-680 for my 88 elite sa50
http://s286.photobucket.com/user/JeepMa ... 8.jpg.html
http://s286.photobucket.com/user/JeepMa ... 5.jpg.html
the crankcase fits just fine.
http://s286.photobucket.com/user/JeepMa ... b.jpg.html
Re: Jug, crank case not same year I suspect.
Posted: Tue Mar 19, 2013 12:07 am
by jeepmaned
Think I may have found what it is....a se50 gasket looks like this.
On second thought found an 87 elite cylinder head that looks like mine.
Posted: Tue Mar 19, 2013 9:15 am
by Pete M
You are correct. I have one apart at this very moment also.
Posted: Tue Mar 19, 2013 10:58 am
by Trafficjamz
That is a gasket for an AF16 block.
You have the wrong gasket.
The pic where it "fits the block"......the gasket is backwards.
Posted: Tue Mar 19, 2013 9:31 pm
by jeepmaned
A little confused....
The gasket honda no. 12191-gs7-680 was the correct no. for my bike, 1988 elite sa50.
The gasket fits my block, is that a af16?
The cylinder head does not match perfectly, it had no gasket on it when I first took it apart, and I made one.It ran, but was hard to start cold. After ordering rings and head/jug gaskets, is when I noticed the difference. When mated there is open spots where air can come in. So what head is this? and will a different gasket solve this?
Posted: Tue Mar 19, 2013 9:34 pm
by paulpauly7
you have a af16 block and a af05e cylinder you need to buy a af16 cylinder kit nows a great time to big bore kit it
Posted: Tue Mar 19, 2013 9:40 pm
by jeepmaned
OK thanks....not sure if I really want that, because of licensing laws having to stay under 50cc's
