Page 1 of 2
86 Spree lost top end
Posted: Mon Jun 05, 2006 3:38 am
by windycity85
My spree used to go about 33 a week ago but since then I drained the gas, loaded it into my car and moved it 350 miles. After cleaning the carb and retuning it, I can only get it to go about 27 tops. Anyone have any advice? I tried to search but couldnt find anything, Im sorry if I missed something.
Posted: Mon Jun 05, 2006 8:17 am
by darat
thats weird
Posted: Mon Jun 05, 2006 9:11 am
by noiseguy
I'd look for something like a disconnected vacuum line or vacuum leak. Is the exhaust still tight?
Posted: Mon Jun 05, 2006 10:13 am
by windycity85
Where about are the most crucial vacuum lines? Im pretty new to tearing these things down and finding out what goes where. I know about vacuum lines just not where each one is on the spree. Im pretty sure the exhaust is still tight but I will check it in a little bit.
I also dont know much about tuning it since I never really messed with it before and it ran fine, then i moved it and it needed to be tuned. The screw with the spring on the outside, i think its the throttle screw is almost all the way in and the other one is about at factory settings of 1 1/2 turn out. Does that sound about right?
Thanks guys!
Posted: Mon Jun 05, 2006 10:50 am
by Spreewell
Might wanna think about laying off the Little Debbies for awhile.
Posted: Mon Jun 05, 2006 10:58 am
by MySpree
maby before you were just rideig down hil.
Posted: Mon Jun 05, 2006 11:01 am
by windycity85
haha I probably should...any other suggestions?
Posted: Mon Jun 05, 2006 12:22 pm
by noiseguy
windycity85 wrote:I also dont know much about tuning it since I never really messed with it before and it ran fine, then i moved it and it needed to be tuned. The screw with the spring on the outside, i think its the throttle screw is almost all the way in and the other one is about at factory settings of 1 1/2 turn out. Does that sound about right?
Ah, no, it does not. Your idle jet (lower one) should be 1 7/8 turns out. Throttle idle screw stop (highest, with spring) should not be "all the way in," it should be about 1 1/2 turns out, but whatever is working for you is fine.
There's only one vacuum line, on the intake manifold going to the tank.
Also, when you put the carb back on, did you get the little plastic part in right? If you did, there will be a little arrow on the outside of it pointing towards the front of the bike. If not, it won't, and your o-rings will be touching. This causes a slight vacuum leak and lowers top speed.
Posted: Mon Jun 05, 2006 1:26 pm
by bigbaer
Was there an elevation change? I know when I moved from Denver to Maryland I had to mess with my old moped to get it running correctly.
Posted: Mon Jun 05, 2006 3:01 pm
by windycity85
no elevation change really, northern WI to a Chicago suburb. I will check the plastic piece with the arrow today and let you know. Thanks for all the help so far guys!
Posted: Mon Jun 05, 2006 3:56 pm
by windycity85
I think i may have found the problem, I dont know the exact name for it but the smaller part of the carb that the vacuum line goes into. Its seperated from the actual carb by a gasket with o-ring seals. Anyways one of the two bolts has stripped a little, therefore not tightening all the way. Could this be my issue??? Sounds like it could be to me please advise!!
Posted: Mon Jun 05, 2006 6:35 pm
by berreta22
yes it could be the issue since it would be considered as a vacuum leak. Just find a longer bolt with a nut and do it that way.
Posted: Mon Jun 05, 2006 7:25 pm
by myhonda
yup. do what he said. my carb is actualy held on just like that. both my bolts striped and i did that with both them wirks great
Posted: Mon Jun 05, 2006 7:58 pm
by windycity85
Ok i was testing it and I found out that was the problem by tightening it the best i could, then riding it and it would go about 31 then when it would rattle loose the top speed would lower to about 25 again. So I fixed that and now it wont even get to 25 again, I really just dont know fellas I need some help.
Posted: Mon Jun 05, 2006 8:13 pm
by myhonda
KICK IT lol no dont kick it. i dont know try cleanin the carb again or ajust the carb.
