Roller weights: grease or no grease?
Posted: Sun Jul 08, 2012 4:32 pm
by zadman2012
I have read much and the concensus is varied. Double-checking that what I see is still true:
1)about half of you run dry roller weights
2)about 1/4 run a sheen of light grease on the ramp plate like the manual says to do
3)the remainder grease the **** out of everything but the pulleys like Honda likes to do on 83-84 Aeros
Most of the posts concerning this topic are older so I was just looking for any changed opinions/thoughts.
Thanks folks.
Re: Roller weights: grease or no grease?
Posted: Sun Jul 08, 2012 5:28 pm
zadman2012 wrote:I have read much and the concensus is varied. Double-checking that what I see is still true:
Thanks folks.
NO GREASE! The manual is wrong. Honda no long uses grease either. No grease!
Posted: Sun Jul 08, 2012 11:30 pm
by zadman2012
Bear45-70 wrote:zadman2012 wrote:I have read much and the concensus is varied. Double-checking that what I see is still true:
Thanks folks.
check. no grease. I hadn't used it, but was starting to worry if I'd screwed up by that. thanks. did clean a fair bit out of the ramp plate though before the new weights went in.
