Is this elite variated?
deuce217
Post by deuce217 »
I found this elite for 500.00 it is whiteand gray. 1988 with 2500 miles. here is a pic of the kick cover, the tranny code is AF05E. Is this variated? Is it worth 500$? And a 2.5 hour drive? Image
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Downsouthdio
Re: Is this elite variated?
Post by Downsouthdio »
Yes variated.. If its running and with title i think its a good deal :thumbwink:
Honda super dio
Corsa
26mm
Sparrow
Post by eliteguy50 »
Yes, it is variated. Looks like an Elite LX. Good deal depends on the body and your total fuel cost too.
Fishman43
Post by Fishman43 »
Ask them to take $50 off the price so you can get a new airbox :smile:
deuce217
Post by deuce217 »
Are there many aftermarket parts for this? Is it the same as the aero 50 motor? If so those seem hard to find good parts for..
50mm BBK (tai)
V-8 pipe
Fishman43
Post by Fishman43 »
I did the Ruckus variator on my Aero, a bore kit from Daywot on Ebay, and a Leo Vince pipe, plus a slightly larger rear tire and hit 48mph on a slight down hill with a full tuck. I regularly cruize around at 40mph with no issue. Getting the carb tuned was the most tedious task since small increment jets are hard to source.
Feral_Sparky
Post by Feral_Sparky »
Fishman43 wrote:I did the Ruckus variator on my Aero, a bore kit from Daywot on Ebay, and a Leo Vince pipe, plus a slightly larger rear tire and hit 48mph on a slight down hill with a full tuck. I regularly cruize around at 40mph with no issue. Getting the carb tuned was the most tedious task since small increment jets are hard to source.
Believe it or not, but my stock '87 elite se50 when I had it tuned right and the weather was warm, it would hit 42mph all day long and even hit 45 a couple times, but once the weather was anything but perfect, it was back to 35mph for the rest of the year.
1987 Honda Elite SE50
Fishman43
Post by Fishman43 »
I believe it, but the time it took me to get too speed VS what it does now are night and day and LOADS more fun!!!
deuce217
Post by deuce217 »
Thats mobbin on a stock scooter! I am not gonn buy this one. The drive... and it is not that clean.
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
Thanks for the help guys!
50mm BBK (tai)
V-8 pipe
elitedio
Post by elitedio »
...and it has some sort of electrical problem.
1989 Elite E with 86cc Dio
veedubh20
Post by veedubh20 »
do dio swap. :thumbwink:
deuce217
Post by deuce217 »
elitedio wrote:...and it has some sort of electrical problem.
Did you buy it?
50mm BBK (tai)
V-8 pipe
