Whats the proper gear oil weight?
lolo123
Post by lolo123 »
Dont have a service manual have a 99 elite sa50. Doing a complete overhaul and need to know the right gear oil to use?
Re: Whats the proper gear oil weight?
not gear oil
motor oil.
10w 30 i think
Refering to manual...page 2-6....MOTOR OIL.10 W 40....90cc's or 3.0 oz.See your service manual anytime at Wikispreedia....at the top of every page....click on links, eezy-peezy... :thumbwink:
maybe 10w 30 is for michigan riders :thumbwink:
lolo123
Post by lolo123 »
k one more question ill be putting my bbk on my scooter this weekend whats a good cylinder head temp range to look for? whats cold whats average and whats Lean?
I had to let a scooter tech work on my Elite 80. The crank seal was leaking and I dont have the tools, so I opted to allow a professional (friend too) to make some money. Upon completion, he informed me that he put 80/90 gear oil in my trans. That is when I first discovered that the recommended oil is 10 W 40. Michigan riders probably safe with 10 W 30. swimmingfree probably using lard.
motormike wrote: swimmingfree probably using lard.
bacon grease :smile:
lolo123 wrote:k one more question ill be putting my bbk on my scooter this weekend whats a good cylinder head temp range to look for? whats cold whats average and whats Lean?
200 is cold and 400 is hot
somewhere in between is good. :smile:
Dio89Elite
Post by Dio89Elite »
I use coconut oil mixed with pineapple juice. :shock: j/k. :geekdance:
In reallity I am using gear oil, synthetic. I've used 10w40 too. I've used either or.
You can use what the manual says or try different oils depending on how 'adventurous' and 'daring' you might be. ;)
Yes, my engine hasn't blown up yet.
No, I really wouldn't try and recommend the coconut oil/ pineapple mix. :mrgreen:
do not use transmission fluid :smile:
Dio89Elite
lolo123 did ya find your service manual?
http://www.hondaspree.net/phpBB3/viewto ... =11&t=2677
Feral_Sparky
Post by Feral_Sparky »
I use 10w40 Motorcycle Oil.
1987 Honda Elite SE50
Feral_Sparky
Hey is that an SB50?
Dio89Elite
Feral_Sparky wrote:Hey is that an SB50?
if you're inquiring on my avatar pic, yes it is! =).
