Wont start after setting a few days
Posted: Wed Jun 08, 2011 7:10 pm
by snappy
If I let my 85 spree set a for a few days it won't start just turns over.If I unhook the air filter tube off the carb and put my hand over it starts right up.Do I have a vacuum issue or a by starter issue.
Re: Wont start after setting a few days
Posted: Wed Jun 08, 2011 9:13 pm
Could be either.
Posted: Wed Jun 08, 2011 9:23 pm
by snappy
Were would you start ?
Posted: Wed Jun 08, 2011 9:54 pm
by martynkim
Clean the Carb First. E tube possibly clogged up.
Posted: Wed Jun 08, 2011 9:58 pm
by snappy
It runs great after it starts ,what's a E tube
Posted: Wed Jun 08, 2011 10:09 pm
Test the bystarter by the manual or use Wikispreedia if you prefer.
I doubt that you have a dirty carb.
Make sure the bowl drain screw is sealing properly.
Posted: Wed Jun 08, 2011 10:10 pm
I'm with Martynkim on cleaning the carb. If it starts with a hand over the bellmouth, it's because it can suck fuel from the main circuit or whatever carb circuit is still functional. The bystarter and/or Pilot is likely gumming up.
The Emulsion Tube is a little Swiss-cheesed brass affair that goes into the Main tower under the main jet. It can become cemented in there and all its little holes get blocked.
Consider buying a gallon can of carb cleaner at the autoparts store. Disassemble the carb and put the parts into the little basket in the can overnight. Push the emulsion tube out carefully with a wood or plastic pusher.
Posted: Wed Jun 08, 2011 10:12 pm
by martynkim
Bear45-70 wrote:Test the bystarter by the manual or use Wikispreedia if you prefer.
Well, I have had this issue before and that is what I did. The problem was cured. Although, it is possible I fixed something by mistake. :shock:
Posted: Wed Jun 08, 2011 10:24 pm
He said:
snappy wrote:If I let my 85 spree set a for a few days it won't start just turns over. If I unhook the air filter tube off the carb and put my hand over it starts right up.Do I have a vacuum issue or a by starter issue.
If it did this every time he tried to cold start it, I might buy the dirty carb, but it only does this if the thing sits long enough the drain the float bowl, not a dirty carb or it would do this on every cold start.
Bystarter is easiest to check, but it could easily be a low vacuum issue, but they bystarter is easier to troubleshoot.
