Warm Up ?
Posted: Wed Jun 01, 2011 8:30 pm
by ute
So do you let By-Starter scooters ( Spree) warm up at all before riding ?
With my RD400 I feel the jugs until warm to touch ( I also have a cylinder temp gauge grafted on )...but that bike is a whole different animal than a 50cc scoot .
I have to admit it seems to run great from dead cold , right through the warm up i can WOT at both no problem at all
Just want to get your ideas
Re: Warm Up ?
Posted: Wed Jun 01, 2011 11:28 pm
Riding off on the bystarter shouldn't be a problem if everything is working OK. Going WOT with a cold engine might not be such a good idea. The Spree top end may be a little toucher than the RD's, but it's good practice to let the heat distribute before you flog it. The cylinder base being colder than the top can theoretically lead to some warpage. YMMV
Re: Warm Up ?
Posted: Thu Jun 02, 2011 12:32 pm
by breaze
So let me get this straight - when the jugs are warm to the touch, she is good to go?
Re: Warm Up ?
Posted: Thu Jun 02, 2011 12:38 pm
by fightingplankton
well, if her jugs are cold... buy her a sweater ;)
Re: Warm Up ?
Posted: Thu Jun 02, 2011 1:43 pm
I feel her jugs until she's smokin' hot........making sure the base comes up to temp and is well lubed.......when I'm flogging away, I'm not risking the chance she's gonna warp.......ouch !!................. :urban: ........for bradmeehan
Re: Warm Up ?
Posted: Thu Jun 02, 2011 8:42 pm
by ute
Ha Ha
I knew this was going to end up with .....Jugs ....lol
sounds like common sense with the warm up
Re: Warm Up ?
Posted: Thu Jun 02, 2011 9:05 pm
by bakaracer
that and you want it warmed up before you put ride it. riding it cold and loading the piston and rings while cold is asking for the ring lands to stretch and wear the rings quicker. the heat makes the metal expand a bit more which tightens up the clearance of the ring ends and piston to cylinder wall clearance of where it needs to be.
Re: Warm Up ?
Posted: Thu Jun 02, 2011 9:08 pm
by SpreeMadness520
Its a spree there built to last, Warm or cold you could drive that thing for a 100 years underwater and I bet it would still run. Yes it is good to wait until it warms up but I didnt worry about it with my spree engine. With my dio engine how ever I give it some time for the cold blooded ***** to wake up. :2thumbs:
Re: Warm Up ?
Posted: Fri Jun 10, 2011 10:33 pm
by Storm
I rate the warm up, as I am running the alternative plug (BPR8HSA as per manual) for extended high speeds, and its an ugly pig if I just jump on and flog it for the first 3 miles. All it takes is a couple minutes idling away and I can usuall hear the bystarter cut off and the revs drop slightly and thats warm enough for me :D
As Wheelman says, YMMV
Re: Warm Up ?
Posted: Sat Jun 11, 2011 3:37 pm
by z50r-ghost
Nice avatar; CLOWN!! Dont get him around #0...
Re: Warm Up ?
Posted: Sat Jun 11, 2011 3:56 pm
I always let any air cooled engine warm up before I go motoring with it.
Re: Warm Up ?
Posted: Fri Jun 24, 2011 11:06 am
by bradmeehan
motormike wrote:I feel her jugs until she's smokin' hot........making sure the base comes up to temp and is well lubed.......when I'm flogging away, I'm not risking the chance she's gonna warp.......ouch !!................. :urban: ........for bradmeehan
HAHAHA!!!!
