Page 1 of 4
where do you get head studs for the dio motors?
Posted: Mon May 30, 2011 11:51 pm
by Majourlittle
I have seen a few builds on here where guys have used studs and nuts to bolt the jug and head down. Where do you guys get those?
This is picture is from the "how to build and tune a fast elite" thread that is stickied in the build forum. Are those studs supplied with the polini head or are they aftermarket?
Re: where do you get head studs for the dio motors?
Posted: Mon May 30, 2011 11:54 pm
by bakaracer
they come in some of the kits. mostly the ruima kits have them.
Posted: Tue May 31, 2011 12:26 am
Most nut and bolt supply stores will have them. I use two different local ones, Tacoma Screw and Valley Nut and Bolt here in the southern Puget sound area. Look in the yellow pages is your best bet for finding you local supplier.
Posted: Tue May 31, 2011 3:03 am
by JJ Joseph
Majourlittle wrote:I have seen a few builds on here where guys have used studs and nuts to bolt the jug and head down. Where do you guys get those?
Most replacement cylinder kits & big bore kits come with the studs & nuts.
Posted: Tue May 31, 2011 3:36 am
JJ Joseph wrote:Majourlittle wrote:I have seen a few builds on here where guys have used studs and nuts to bolt the jug and head down. Where do you guys get those?
Actually that is wrong. The high dollar kits come with studs. Most do not come with studs.
Posted: Tue May 31, 2011 11:28 am
by Majourlittle
I assume that the threads are going to be M8-1.25, but does anyone know the length of the studs in the kits? what about thread length?
If I used these studs, what is the torque spec used on the high end kits? Is it the same as that of the standard bolts or is it more?
Posted: Tue May 31, 2011 1:53 pm
Majourlittle wrote:I assume that the threads are going to be M8-1.25, but does anyone know the length of the studs in the kits? what about thread length?
Measure the length of the head bolt and add 3/4 of an inch. This isn't rocket science.
Posted: Tue May 31, 2011 1:59 pm
by Trafficjamz
M6
Posted: Tue May 31, 2011 2:30 pm
Use the same torque spec as for the bolts.
Posted: Tue May 31, 2011 10:44 pm
by JJ Joseph
Bear45-70 wrote:Actually that is wrong. The high dollar kits come with studs. Most do not come with studs.
Can you knock of the continual "Actually that is wrong" rant? All decent kits come with studs except for the $29.95 Lawnboy overhaul kits. Maybe that's what you're thinking of.
Posted: Tue May 31, 2011 10:50 pm
by Trafficjamz
JJ Joseph wrote:Bear45-70 wrote:Actually that is wrong. The high dollar kits come with studs. Most do not come with studs.
The polini kit does NOT come with those studs. But maybe that is not a "decent kit"
Posted: Tue May 31, 2011 11:24 pm
Greetings;
Quoth JJoseph
It sounds like you believe the Supreme Insult to someone who disagrees with you is to call him a Lawn Mower mechanic. What've you got against mowers, anyway? Did you lose some appendage to one? Maybe you shouldn't have mounted the ignition switch behind the rotor?
Tuning lawn mowers for performance isn't much weirder than tuning obsolete 50cc smoker-Scooters, truth be told. Some
Mower Tuning can be downright interesting, in fact.
Hmmm, think they're Freeway-Legal?
Posted: Wed Jun 01, 2011 12:22 am
by bakaracer
malossi kits dont come with them either. the only kit I know that comes with cylinder studs is the ruima kits. im sure there are a few others but the ruima for sure comes with cylinder studs
Posted: Wed Jun 01, 2011 4:44 am
by 808BMW
My $100 bore from tazland came with studs (no nuts though
Posted: Wed Jun 01, 2011 5:50 pm
The shut your cake hole when you don't know what you are talking about. Then you won't get told you have your head up your *.
