Page 1 of 2
Gio?
Posted: Mon May 02, 2011 5:01 pm
by SpreeMadness520
Gyro dio swap? That would be bad@ss
Re: Gio?
Posted: Mon May 02, 2011 6:43 pm
by MopedMark
That would not work
Re: Gio?
Posted: Mon May 02, 2011 6:44 pm
by Trafficjamz
MopedMark wrote:That would not work
Anything is possible
Re: Gio?
Posted: Mon May 02, 2011 6:58 pm
by SpreeMadness520
Re: Gio?
Posted: Mon May 02, 2011 7:06 pm
by xxjareebxx
How is the the gyro even done for the 2 wheels
Re: Gio?
Posted: Mon May 02, 2011 7:09 pm
It's tricky..........
Re: Gio?
Posted: Mon May 02, 2011 7:17 pm
by eliteguy50
A handlebar linkage to control throttle in the turns would be wicked. Dual engines out back for an independent rear suspension. While you are that far, might as well run a bag for the seat and dual front disc brakes.
Re: Gio?
Posted: Mon May 02, 2011 7:18 pm
by MopedMark
Trafficjamz wrote:MopedMark wrote:That would not work
FALSE
Re: Gio?
Posted: Mon May 02, 2011 7:31 pm
by Trafficjamz
MopedMark wrote:Trafficjamz wrote:MopedMark wrote:That would not work
FALSE
Re: Gio?
Posted: Mon May 02, 2011 7:56 pm
It would be easier to date my sister.............
..........yeah, no sister.........
........what's a "bag" .......eliteguy50 ??oh, colostomy
Re: Gio?
Posted: Mon May 02, 2011 11:30 pm
by eliteguy50
motormike wrote:It would be easier to date my sister.............
I guess if you are a hardcore long distance racer, you could install a colostomy setup in YOUR Gyro. I will take the pit stop.
I meant an air bag suspension system for the seat. Allowing better tuning for rider weight and riding conditions on the fly. You would replace the current shock setup with the bag and attach it to a subframe. The subframe would hold the independent system in the rear. The seat to subfame would only mover in and out, no pivot. If you need a visual, Youtube the mp3 and then put that front end in the rear of the gyro while adding two engines to it.
Re: Gio?
Posted: Mon May 02, 2011 11:48 pm
I can be dense.......but I've never heard of such a described bag set-up. Is this being used now?.....on what?
Re: Gio?
Posted: Tue May 03, 2011 12:36 am
by eliteguy50
motormike wrote:I can be dense.......but I've never heard of such a described bag set-up. Is this being used now?.....on what?
They are not being used on any current production scooters. Mostly on heavier applications. Have you ever followed a truck and read "air ride equipped" on the back or side of it? They have also broken into the custom cars market because they are cheaper and easier to install than hydraulics but if you want real hopping skills, stick with hydraulics. Air ride shocks are also available and have been used for decades. This is the same concept only they use a 'soft' bag to hold the air and act as the load bearing spring.
http://image.chevyhiperformance.com/f/9 ... ension.jpg
Re: Gio?
Posted: Tue May 03, 2011 12:54 am
Okay.......yeah, I had Gabriel Hi-Jackers on my Vicky
Re: Gio?
Posted: Tue May 03, 2011 4:24 am
by veedubh20
FALSE
It does work, rear gyro swap in a moped and scooter, if you got big cash in a wallet.
Someday, you should go to japan.
Go. Check out YouTube video from japan..
