stroker auto start installation
KINGÔäó
Post by KINGÔäó »
first time installing one of these. just need you help on this.
Graphics Artist Vfx Car Collision
z50r-ghost
Re: stroker auto start installation
Post by z50r-ghost »
KING, can you explain a little more about what you are needing help with? Sorry dude, my brain isn't working today.... J
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Remote starter?
Don't feel alone guys, I don't get it either.
KINGÔäó
Post by KINGÔäó »
electic start sorry guys... is there a difference between a stroker start and a stock electic start? same way to install it?
The starter motor just spins the crankshaft. It doesn't know how far up and down the piston is travelling with every rotation. On a couple of my builds, higher compression caused the starter to struggle a bit - sort of "pause" as the piston approached TDC. This issue disappeared when the engine was "Pre-Kicked" a couple of times to spread lubricant. The late, lamented MadDog frequently boasted of a mysterious "High-Torque Starter" he had installed in the past, but nobody seemed to be able to obtain any further information about this device.
If your compression remains in viable territory, any starter should do the job.
tru72
Post by tru72 »
wheel man. Back in the 90s there was such a thing. We had a few lying around in my shop maybe last year, I totalled spaced and sold them, tried to get more, no dice.... There are still a few flying around the moped community...
