1999 honda elite
1999 honda elite
i have a kick start problem.kick it down wont come back up.is there a return spring broke.thank you tony
Re: 1999 honda elite
Yes!tony wrote:i have a kick start problem.kick it down wont come back up.is there a return spring broke.thank you tony
Removed the kick start lever and take off the cover, it should be obvious.
1984 Honda NN50 Gyro
1986? Honda Aero 50
Served Onboard 94-97
1986? Honda Aero 50
- Trafficjamz
It is probably just jammed up
The spring is pretty robust part....I have never seen a broken one.
- wikked_spree57
They can slip loose from the catch, but your most likely problem is the assembly needs a good greasing. If the cup gear goes dry the whole assembly will stick like none other.
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned
grease the springs, starter idle, and the spindle. had this problem before, just needed to replace grease.wikked_spree57 wrote:They can slip loose from the catch, but your most likely problem is the assembly needs a good greasing. If the cup gear goes dry the whole assembly will stick like none other.
http://www.cheapcycleparts.com/model_ye ... blies/8595
grease 10,11, and 13
Graphics Artist Vfx Car Collision
