Need help fixing up Elite SA50P
Posted: Thu Nov 25, 2010 1:33 am
Hello every one. I got my scooter last month for $200 but just now have time (thanks giving brake) to fix it. If you you the link to other post that could answer my question, plz give me, I have looked at the site for two days and still lost.
The scooter could run but was in nasty condition, here are some (other than ugly cosmetic):
-cannot start with ignition (kick start works well any time).
-when it runs, it sounds so loud like it is gonna falling apart, like it is going so fast but actually it can't never get over 25 MPH.
-if I open the throte all the way it would become weak and faint on the way.
-it has 2400 miles already
So I took everthing apart to clean them up and found out:
-the gas tank is all rusty inside.
-good thing: all the lights works, and speedometer works, gas gauge works
-battery is dead
-the frame says 1999 SA50P
-when I sake the muffler it sounds like it has bunch of sand inside, and along the pipe there are a lot of soldering spots
-the air filter is not there any more, who knows since when.
-the rear wheel shakes so bad when in rolls
-engine oil looks like has been in forever, brown and nasty, not much left when I open the screw to let it out.
-i broke the pistol when trying to get the flywheel out ^^.
My questions are(I don't have any Grinder or any kind of machine available):
-what could cause for low performance and noisy symtom of my scooter
-is mine Elite S, SA elite or SE elite.
-is mine restricted? how can I de-restrict it
-should I buy a stock muffler or mod one to replace (I saw a lot of ppl here using V8). for mod one do I have to mod anything else(like get another carb...)? I can afford to buy some stuff but I can not have any machine so if the mod parts require me to cut or solder I can't do it. Other than that I will go for better performance.
-can I clean my gas tank or have to buy new one
-what is the best way to clean the engine at home
-how to fix the shaky wheel problem
Thank you very much and I appreciate any answer to any question. You guys can give me the link or key to search in forum if you know the answer is somewhere in here.
If this is wrong topic please move it or tell me the right one. I'll move it myself.
-battery is dead
