this should be the last problem,bogs after about 70 yards
Posted: Thu Jan 26, 2006 7:23 pm
by Mike
my problem is that it will run good for about 70 yards and then it will start to bog like its not getting enough gas. its a 1986 so i have the air screw at 1 1/2, the idle speed screw is at the highest idle speed in which the wheel doesnt move, and the throttle needle is on the 4th notch down... The vacuum line i put on is a really small one that probable came off of a motorized r/c car, could this have anything to do with it? AND i have the air box box tube sealed off good. size 65 main jet. it also seems like its burning to much oil because there is alot of white exhaust coming out.
ONCE THIS IS SOLVED ILL BE GOOD TO GO
Posted: Thu Jan 26, 2006 7:25 pm
by Mike
O, and the bowl IS filling up with gas i checked
Posted: Thu Jan 26, 2006 11:36 pm
by JF
With all of that white smoke coming out, it might mean that either the exhaust is clogged up, the carb's running too rich(unlikely, but still a possibility), or there is too much fuel getting in the carb(flooding). You should check those things out first, then check for vacuum leaks around the intake manifold area by spraying a little starter fluid around the gaskets. If the engine RPM's go up or down when you do this, then you know that there is a vacuum leak somewhere there.
Sounds like everything else checks out good though, and no the smaller vacuum line shouldn't hurt it. To check the fuel flow, disconnect the fuel line from the carb, and turn over the engine for a few seconds. If it flows good then that shouldn't be the problem. However, if it looks like its a little slow on the flow, then you might want to consider getting a slightly larger diameter tube for the vacuum line and/or you might need to clean out that fuel valve really good...
Let us know what you discover after you test the things above out good.
Good luck,
JF
Posted: Thu Jan 26, 2006 11:49 pm
by ryanmcfinney
I have white smoke coming out too. From what i can tell its from running too rich and when the muffler gets hot it burns off the extra gas in the exhaust. Once it warms up here I am going to adjust the carb screws and see if that solves the problem...
Posted: Fri Jan 27, 2006 10:42 am
by noiseguy
Sounds like your idle jet. I'm guessing that the Spree runs about 30-60 seconds, then shuts down as the bystarter pin drops into place. Mine does this every spring (and every spring I reclean the carb.)
Posted: Sun Jan 29, 2006 1:19 am
by Mike
everything in the carb is clean
