motor swappin a spree...
Posted: Wed May 05, 2010 10:11 pm
by mustangwagz
SO..has it been done and is it possible...
84 elite 125 motor into a 86 spree...do-able?
whatta yinz think.
Re: motor swappin a spree...
Posted: Wed May 05, 2010 10:15 pm
by Trafficjamz
mustangwagz wrote:SO..has it been done and is it possible...
whatta yinz think.
Isn't the 84 elite water cooled?
Posted: Wed May 05, 2010 10:21 pm
by mustangwagz
water cooled 4 stroke from what ive read
Posted: Wed May 05, 2010 10:27 pm
by Trafficjamz
Sounds like alot of work......But it would probably be nuts. :crazy:
Posted: Wed May 05, 2010 10:40 pm
by Bandit240
If your going to do that, you may as well use a CH150 engine since they are the same size outside.
Coming from someone that has taken apart a few Elite 150's, i dont think the spree has enough frame to hold all the crap that engine needs.
Posted: Wed May 05, 2010 10:45 pm
by mustangwagz
ahhh ok, well only reason i thought of this is cuz supposedly the elite i found has title but its not in the guys name..
so i might have to do the impound deal to get it re titled in my name..
Posted: Wed May 05, 2010 11:52 pm
by PimpinSpree
anythings possible. If your a good fabricator/welder you could try it. I doubt the rear plastics would fit on it
if you don't want all the headaches though, just get the stuff for a dio swap.
Posted: Thu May 06, 2010 6:55 am
by oldrd350rider
What about a CH150 into a CH80 frame?
Posted: Thu May 06, 2010 7:33 am
by Trafficjamz
oldrd350rider wrote:What about a CH150 into a CH80 frame?
That would be alot easier to do. the ch80 frame is way bigger and the mounts are very simular.
Posted: Thu May 06, 2010 3:50 pm
by wikked_spree57
I did CH150 in the 80 frame. I plan to do CH150 on a Spree this summer if I can find a donor Spree. Only catch is, sacrifice rear panels...
Posted: Fri May 14, 2010 9:05 am
by wreck
Anyone ever done a CH80 into a spree frame?
