Accptable number of kicks to start?
skelter79
Post by skelter79 »
I bought an 87 Spree last fall with 4900 miles on it. It runs great but the only thing is when its cold I have to kick it 25-30 times to fire it up. Now when its warm it's a totally different story, one maybe two kicks. Any ideas why it's so hard to get started? How many times does it take to kickstart your Spree?
Spreetard
Re: Accptable number of kicks to start?
Post by Spreetard »
sounds like your bystarter is bad. :imo:
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
mustangwagz
Post by mustangwagz »
wow bet your leg gets sore! lol
anyhow :b2t: to answer your question, mine takes ONE Kick regardless of temp...
Download the manual and check to make sure your bystarter is working, in order for it to work properly from a cold start, you'll need battery power though.. (correct guys?)
also, check your bystarter passage in the bowl of the carb. (little brass do-hicky in the corner of the bowl) make sure its clean and you can transfer liquid from the bowl into that little round cylindrical passage, OR vise-versa.
from what i've read also, these scoots dont like cold weather, although, what 2 stroke does!? my saws run fine, but i had to get cold weather kits for them.
-Zac :coolcruise:
05 vinson
78 bronco (Log skiddin Hog!!)
Saved
Post by Saved »
My Elite takes 1 kick. 2 if I'm lazy. Before I cleaned the carb 3 times and changed the Bystarter, it would take 15 or so.
In the barn::
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
Workdog & Iggysepia for parts & quick shipping.
Evilone for buying my SA50P.
skelter79
Post by skelter79 »
As far as battery power is concerned, I installed a new battery. The electric start worked worked for a week and then nothing. I ride my scoot every weekend ( I don't want it to sit up and develop problems) at least 3 or 4 miles and everything is tuned up as far as plug, air filter, etc..
