How do you remove upper speedo cowling on 86 Spree
I've removed the two silver Phillips screws from underneath, the two plastic black screws on the sides, and the 6mm cap screw facing the driver. Something is loose and making a racket. Perhaps the speedo. Don't know until cowling removed. Help. Duck
Re: How do you remove upper speedo cowling on 86 Spree
ok, you need to use something to pry out on the lower half to get it over the stud sticking out(where the cap nut was) then you can get to the hold down for the top part of the cover, it needs to be pryed off the same stud. then it will just pull off.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Wow, I'm glad I asked! Thanks for the info. Duck
- fightingplankton
yeh, there is a little tab which goes around that stud...i didnt know that on my first speedo plastic...now that tab isnt there any more.
once you get that off, dont forget to take the speedo cable off the front wheel(mine was really short and i couldnt remove it from the speedo)
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
- FTP 140cc Kit
- Lifan 90cc auto
