Dio Gears in a SE50?
chevyguyjay
Post by chevyguyjay »
ok guys, i wanna know y people say this wont work? does anyone know y? whats the differences between the blocks? (SE50, SA50) :?
~2004 Geely Fashion~
Dac
Post by Dac »
dude. Check this out...
this is the SA50 block thing. As far as i know, 93 and under SA50s were the same as the SE50s (could be wrong)
Now when you buy a gear kit you dont get everything. Just the two sprokets. So im theory, Just find one some parting out a dio motor. Snag all the inerds of the gearing. Then buy a gear kit. And it should mount in and go.
I might try this on my 92. That and port the case so it will take a 72cc bore kit. :wink:
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
chevyguyjay
:shock: BRAINSTORMS :shock:
chevyguyjay
ok guys, i have my dio gears. :D ordered them from VT cycles friday. i did some research. these gears will work. :D wait a few more days till i take some pics. i will be going into a lot of detail of just how im making these gears work. ive got a base line of what my aero runs now. 43mph flat. :wink:
Burgleflickle
Post by Burgleflickle »
dukemartini wrote:
Dac wrote:
jstone wrote:d***, if this works it will change life as we know it!
FOR REAL! :shock:
It would change everything!
Holy Sh#t do I hope this works!
If it works, I think I'll cry a little.
"This whole thing is a travesty and a sham and a mockery! It's a traveshamockery!"
"No making up words sir."
"Burgleflickle!"
chevyguyjay
ok, so the dio axle is the exact same as the SE50. no problems there. however, i call it the idler gear needs some machining. this gear has splines on it, and the shaft itself is a little longer. all im ganna do is shorten the shaft, and have the splines cut down just enough so i can have the gear pressed on. thats it. i will post pics once the gear is machined. :wink:
chevyguyjay
1. the before look. stock gears on the right, dio gears on the left.
2. u can c just how much longer the shaft is on the dio gear on the right.
3. in this pic, this is where i have to have the splines machined down, so i can have the gear pressed on to the shaft.
4.on the axle shaft, the stock gear has splines with 2 snap rings. the dio gear will have to be welded on. im not exactly sure if my buddy will weld it, or do something else.
5. the dio gears in the SE block.
6. once the one gear gets pressed on, i should be good to go.
Dac
Post by Dac »
you do realize something right?
YOUR CHANGING THE WAY THINGS WORK! :twisted:
Your like changinging the fact that SE50s dont have gears! Why are you making the dio seem less cool?!?!?! :lol:
BTW what is the gear ratio you are using?
chevyguyjay
come on dac, what u tring to say? u tring to say this Aint ganna work? being im not a big dio fan anyway, this is ganna be very interesting once i get these gears in. it will truely be one-of-a-kind. :wink: oh, 9-1.
Dac
Post by Dac »
no dude im just joking arround. But you are changing everything.
"being im not a big dio fan anyway" All i got to say is own one. :lol:
But no dude. I really hope this works. I really would love to see a member of this board to be the big ground breaker.
chevyguyjay
no sweat man. i might of just took it the wrong way.
PM sent. 8)
Post by Kenny_McCormic »
By doing this the price of SE50 motors will SKYROCKET!!!
burnt_toast
Post by burnt_toast »
Kenny_McCormic wrote:By doing this the price of SE50 motors will SKYROCKET!!!
Hah I wouldn't go that far.. dio blocks will reign supreme in the honda realm me thinks :P
But this is a step! My friend has an 87 SE50 and would be very interested in something like this, he's trying to overhaul his elite but stay 50cc and catch up mine lol
With these gears he'll be almost there. :lol:
projects galore :nerd:
jstone
Post by jstone »
Once you and your buddy get everything worked out, you should mass order some gears and go in to production. I think it would be a BIG money maker just based on the amount of people that visit this site asking for gears.
Burgleflickle
jstone wrote:Once you and your buddy get everything worked out, you should mass order some gears and go in to production. I think it would be a BIG money maker just based on the amount of people that visit this site asking for gears.
I'll buy for sure
"Burgleflickle!"
