72cc dio motor MPH question
Rob
Post by Rob »
well got to take out my scooter the other day and i cant get it over 42 mph.
i am running stock muffler derestricted and stock variator and stock gears
what should i do to get the full power out of this motor?
i really want to see this scooter go 55 mph and i think with the right stuff i can get it there
its a 95 honda elite s
what do u guys think i should change on this setup?
2001 honda elite s 50cc
1995 honda elite s 72cc
mookie
Re: 72cc dio motor MPH question
Post by mookie »
credit limit on your card?? :hi:
for long as i can remember
Rob
Post by Rob »
money is not a problem here
bakaracer
Post by bakaracer »
Rob wrote:well got to take out my scooter the other day and i cant get it over 42 mph.
Get a aftermarket variator and some 9to1 or 8.5to1 gears. Did you rejet the carb?
Read Flash III Build Chronicles in Scooter Builds for what's possible with the stock carb and pipe.
A variator (mine's a Polini but Keli should perform very well too...) with 9:1 gears and only stock power was enough for 48-ish. Your BB should push that easily above 50. That ain't 55 however. :sad:
To get there I believe you'll need a pipe of some sort. I chose a V8 because it's a nice compromise between the low ceiling of the stock and the gutless low-end I've read about with full-race chamber pipes. Mine was relatively cheap at JiangWayne's a few months ago, but I've noticed the price went up about $50 since I bought mine.
I do not believe a manifold/carb is necessary to achieve 55, but an aftermarket filter and a substantial upjet is necessary. I ended up with around a 101 by the time I resolved some erroneous temp reading confusion. You may find an 88-92 will suffice if you retain the stock airbox, suitably drilled, but I believe the max performance suffers.
That said, if you plan eventually to do a heavy-breather pipe and replace the carb/manifold with something bigger, save time and money by installing 8.4s instead of 9:1s initially. Even without the carb, holding a 55 cruise speed will be easier; once up to speed you can relax the throttle and ride the torque at lower revs.
veedubh20
Post by veedubh20 »
mookie
Post by mookie »
you owe us 5 minutes. :jack:
burnt_toast
Post by burnt_toast »
veedubh20 wrote:hope this video help.. http://www.youtube.com/watch?v=LZpBrYju-J4 :popcorn:
yup, check out akped driver's setup
used that as a basis when building my own ministroke corsa setup
9:1 gears will be cherry for you
plus aftermarket variator
will need to change center and grab springs in clutch too
then she should boogie :2thumbs:
projects galore :nerd:
mookie
Post by mookie »
Rob wrote:money is not a problem here
Cool ! :rock:
