01 Honda Elite- ZX headset swap, disk brake, DIO FUN
Spruckus
Re: Too many build threads- 01 Honda Elite
Post by Spruckus »
If you get a set of mint sides I might take the scuffed ones off your hands for the air-elite
hothatch85
Post by hothatch85 »
zx trans worked well for about the first 10 mins of riding... tell me your clutch set up, i have the zx pulley, koso 2k contra, polini clutch with blue springs almost maxed and the evo bell.
bottom end was great with the zx kit and now its scary to ride. it chatters and shakes bad from a stop. if you slow way down and rip it from a low speed the clutch will slip, engage and repeat. jarring you back and forth.
hothatch85
update,
tore down the motor to go 117cc watercooled
yeeeeeeeee
Xxbeejay45xx
Post by Xxbeejay45xx »
You getting G9's taida Lc kit? What exhaust you gonna run with it?
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
hothatch85
Yes going with g9s taida bore and crank. I'll use the same taida exhaust he's running on his 114
Got my rm65 radiator, this thing is small but should be enough with a small e fan on it. I cut out the right side of my glove box and moved my horn. It will sit perfectly in the cowl, at least that's the plan
Xxbeejay45xx
Ohh sleeper!! Cool one there, haven't seen a hidden radiator like that yet. Great idea!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
hothatch85
Got the stripped out rotor bolts out of the zx wheel. Threw on the ncy 200mm rotor and caliper for fitment. Should work good :geekdance: I'm going to strip these wheels and refinish them once it gets warmer out. Lots of stuff left to do
hothatch85
Got the bore and crank ordered
Still need the big black ct, evo bearings, taida exhaust and taida mini rotor kit :) but! As soon as I order the manifold and have the bore and crank I'm making a trip to Denver to drop it off with 1man for building
Starting the disc conversion real soon. Just need to order the forks and get my headset ;)
MrJumps
Post by MrJumps »
This build has literally inspired me to do a spreedio sawp and possibly aim for a 117cc wc kit too...
hothatch85
Thanks man! Glad to be of inspiration. A lot of my ideas are still in my head I need to get down and get started on this
1man8scoots
Post by 1man8scoots »
Did you get the square bore 54? I only have the 2 rounds so far
hothatch85
Yeah I went with the square 54,
I got my legs ordered thanks to the SSS Christmas sale :)
Picking up my next part personally from Bones this week! ;) ;)
hothatch85
A huge THANK YOU :geekdance: to Bones for this hook up. Nice meeting you man :) wish I lived down here.
Dio headset, speedo, handle bars, master cyl and brake line. Pretty much finished off my list for this disk swap. Can't wait to get home and get started :))
hothatch85
Forks came in from SSS, got the front end all mocked up. Metropolitan tree, zx wheels, rrgs forks and ncy brake parts. Can't forget about the all important 10-12mm axle sleeves :)
hothatch85
Sold my zx wheels to a local. I'm going for bigger and better and unfortunately the zx wheels couldn't get me there. However the new wheels that are replacing them are HOT.
