Page 4 of 5
Re: Spreedio Performance ... AF16 BUILD
Posted: Sun Apr 02, 2017 9:41 am
by Xxbeejay45xx
Nice job it's coming along
Posted: Sun Apr 02, 2017 8:32 pm
by jakubman1
112 Is way to lean my plug is white af!
Temps were 340.
Posted: Mon Apr 03, 2017 11:59 am
by jakubman1
Cleaned my stage 6 filter 1 time and the glue is already starting to come undone. I used FAB1.
Posted: Tue Apr 04, 2017 12:37 am
by benji
I've been figuring out that stage6 quality is crap.
Posted: Tue Apr 04, 2017 7:54 am
by jakubman1
I do also have the polini filter buuut. should i leave the plastic cone on it? My rear tire kicks up all the dirt on the tage 6 filter
Posted: Tue Apr 04, 2017 12:37 pm
by benji
Yah leave the guard on it or use the oem box. My foam filter is a liability in the rain.
Posted: Tue Apr 04, 2017 7:40 pm
by jakubman1
Anyone got port degrees for the contessa?
Is that even the term ?
Posted: Wed Apr 05, 2017 11:45 pm
I ran that Polini filter, briefly, on one of the Flashes. maybe the 90cc mini-stroker. I can tell you that snapping that rain cover over the foam filter caused a hopelessly rich situation - it barely ran above idle - because the limited area of the sum of the holes in the plastic cover increased the negative pressure so significantly. If you must run it, be aware of its airflow-limiting effect and be prepared to downjet by 3 or more sizes. I personally think it strangles anything bigger than 50ccs. There was nothing wrong with the Polini filter itself, but the plastic rain cover stifles airflow. A lot.
Posted: Thu Apr 06, 2017 4:05 am
by benji
I wish there was a happy medium w aftermarket filters. It seems that they either flow too much or not at all. I've been looking at these remote mount airboxes for go carts lately. Ugly but look interesting.
Posted: Thu Apr 06, 2017 4:07 am
by benji
Check this thing out. Looks like an air filter from a ww2 tank.
http://m.ebay.com/itm/44mm-Air-Filter-f ... ING_ACTIVE
Posted: Thu Apr 06, 2017 9:24 pm
by jakubman1
So my top speed was 55. Sounds like it's winding out topped out
Posted: Fri Apr 07, 2017 8:39 am
by R1Titan911
Thats sounds good for a Contessa? Swap rollers?
I have a Corsa that can fix that top speed
Posted: Sat Apr 08, 2017 1:56 pm
by jakubman1
New top speed 61mph with 8 gram rollers. Pretty boggy though
Posted: Wed Apr 12, 2017 10:13 am
by jakubman1
Does anyone know the compression ratio of the corsA?
I'm bout to get the corsA ported !!!!
Posted: Thu Apr 13, 2017 7:41 pm
by jakubman1
Does anybody know the compression ratio for the corsA kit ?
