spree-dio swap time!!!
Petrock's 1984 Spree
Re: spree-dio swap time!!!
Post by Petrock's 1984 Spree »
Wow, looks professional to me!
Great job! :smile:
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Spreetard
Post by Spreetard »
Well, I got the boost port cut today, and prepped everything to put the crank in. The port has been adjusted a little bit, and the engine should be running by next week.
I also bought a lifted 91 subaru legacy, my 5th Subaru.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Spreetard
Post by Spreetard »
Well, the crank is in the engine, the hondabond is cured. Brand new Honda OEM NSK bearings now are nestled on either side of a 44.4mm Teflon stuffed Ruima crank. There is a bit of porting I still want to do, but the mighty mini-stroked Malossi is nearing completion. In light of the crankshaft being added to the build, I think I need to get a bigger carburetor, as my 21mm is a bit on the smallish side for my setup. :roll:
I'm thinking 28? 26? Suggestions?
Ol' Red
Broken...
Spreeio
1987 Spree
What speeds are you looking to get out of this crazy thing?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Spreetard
Post by Spreetard »
A minimum of 70. This is being built to go riding with full size motorcycles as well as other scooters. If I can push the 6.3 secondary gears... ??? I don't want to quote a number. Faster than safe. I want to be able run 55-60mph down the highway at partial throttle.
Ol' Red
Broken...
Spreeio
1987 Spree
Spreetard wrote:A minimum of 70. This is being built to go riding with full size motorcycles as well as other scooters. If I can push the 6.3 secondary gears... ??? I don't want to quote a number. Faster than safe. I want to be able run 55-60mph down the highway at partial throttle.
I really hope you got some good brakes on this sucker :nervous:
Lol minimum of 70, I'd want a diaper if I tried that on a spree
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Spreetard
Post by Spreetard »
:oops: The brakes, for now, will be stock. I want a disk setup, but first things first. The spree brakes worked surprisingly well around 50mph though...
Ol' Red
Broken...
Spreeio
1987 Spree
Yours is gonna go that fast too petrock :crazy:
With 8.44:1 secondaries?
Oh boy :nervous:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Petrock's 1984 Spree wrote:With 8.44:1 secondaries?
Oh boy :nervous:
60mph @9000 rpm with those gears ! :smile:
If you can get your corsa to rev to 10000rpm 70mph could be closer than you think. :wink:
Hahah okay good! The thought of 70 is still way sketchy to me.
I'll leave porting decisions for a day a long way down the road. I'm perfectly fine with whatever guido did to make the corsa the way it is for now :thumbsup:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
matzke3
Post by matzke3 »
[quote="Spreetard
Currently the bike is in a box, torn down to the smallest of components.
:geekdance: I have an 87 Elite 50 speedo for it. :ndance:
[/quote]
The 87 elite speedo will fit a spree?
How fast do the 9:1 gears get you?
matzke3 wrote:
The 87 elite speedo will fit a spree? Yes
How fast do the 9:1 gears get you? 50mph or so
matzke3
Post by matzke3 »
SAWHEET. My sprees an 86 and I still have the speedo from the 87 elite donor. Ill spin the odometer to match and swap them. I ordered 9:1 gears and they havent arrived 50 MPH is around my goal.
matzke3 wrote:SAWHEET. My sprees an 86 and I still have the speedo from the 87 elite donor. Ill spin the odometer to match and swap them. I ordered 9:1 gears and they havent arrived 50 MPH is around my goal.
Sorry to burst the euphoric bubble but those gears will not fit in a Spree engine
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
