Page 3 of 3
Posted: Mon Aug 27, 2007 11:29 am
by DougM
I have been trying to start it with it hooked to a battery charger. It cranks good. All checks came out fine. It has spark just very weak. It has a new plug. I was thinking that the CDI must be bad, but it should just turn on and off the coils and not the intensity of the coils. It quit while riding and would not restart. It used to start everytime and then this one time it quit and thats it. Thanks for your help.
Posted: Mon Aug 27, 2007 1:33 pm
by snikro
Well, what is your definition of a weak spark? What does it look like with the plug out?
Posted: Mon Aug 27, 2007 2:23 pm
by DougM
If you look closely you can barely see it. At first I didn't think it had spark, but then we saw it. Of course it was daylight, but It was very thin and faint.
Posted: Mon Aug 27, 2007 2:25 pm
by DougM
It has compression within specs, but won't even try to fire on starting fluid either. so I have eliminated the fuel aspect of the equation.
Posted: Mon Aug 27, 2007 8:13 pm
by Kenny_McCormic
In daylight any spark will look weak.
Posted: Mon Aug 27, 2007 10:39 pm
by DougM
Well, this is a very small spark and with compression won't fire starting fluid. So I am at a loss.
Posted: Tue Aug 28, 2007 11:23 am
by snikro
Mine looks very weak and puny in the daylight too, although the scooter runs fine. I really do recommend you try it in a darker atmosphere, such as night, because as said it really is hard to see during the day. Also are you sure you checked simple things such as the air filter etc?
Posted: Tue Aug 28, 2007 12:16 pm
by rickc
If the spark is blue/white then it's good.
If the spark is yellow/orange then it's weak.
Posted: Tue Aug 28, 2007 1:16 pm
by Kenny_McCormic
Are you sure you have good compression? Remove the spark plug and put 5-10 drops of oil (anything will work i use regular 30weight oil because i have a squirt bottle of it) down the spark plug hole, then crank the motor over for a few seconds with the sparkplug not in. Put the plug back in and try starting it if it runs you have bad compression.
Posted: Tue Aug 28, 2007 2:26 pm
by DougM
Thank, I tried that too. I also tried priming the down the plug hole and still have no fire. I have good compression according to my gauge. It won't fire starting fluid so i assume its spark related.
