Re: opinions on best variated AF05e big bore kit
Posted: Mon Feb 17, 2020 1:50 pm
Ive been tempted to order a polini from the fatherland for the wifes aeroharleyracer59 wrote: Mon Jan 27, 2020 10:44 pm so to date ive purchased and ran a polini iron cylinder, metrakit iron, pinasco iron \, zeda racing iron, italkit aluminum.
the polini kit is a torquey upgrade over stock. not the fastest or most rpm but its a reliable tough cylinder with easily obtainable replace ment parts. will work with 1 base gasket but liked 2 base gaskets a lot better. was faster more torque and gained 400 rpm has a top rpm of 8900-9400 depending on carb size and exhaust pipe selection. iit can be ran hard and keep going.
ill add more on the other cylinders as I get time
