Dies after hitting bumps
scootfast
Re: Dies after hitting bumps
Post by scootfast »
If you bought one of those cheap spark plug wires from ebay I would check that. I learned the hard way. It was a long push home. If you want quality parts always ask Brandon at scooterswapshop. He"ll take care of you. Lots of know how. Jim
mitsukid124
Post by mitsukid124 »
I stated in my last post that i figured out the issue. The choke bowl was dented. This is caused by someone installing the carb and switching the positions of the two carb mounting bolts. If you put the long bolt in the wrong side it dents it and does not allow the bystarter to choke the motor after it is warm. The dent can be seen on my second page.
Therefore this has been resolved.
