The '08 block will have the better set of gears. The recall was only for emissions so you will be safe with those mods assuming you keep the pipe instead of using the '08 exhaust.lowblueranger wrote:The zuma is a 2002- but I pulling the engine and putting a 2008 engine in- the crank's stripped on the outer varaiator fan and the nut is welded to the end of the crank. It has alot of parts on it-so I'm stripping it down and transfering the malossi 70cc clutch, arreche carb-to the new engine. I have the elite all together now and running, It's so awesome!!!! I just haven't installed the gears, but new tires and metropolitan wheels to be installed tomorrow.
Any Iowa riders?
Re: Any Iowa riders?
- lowblueranger
- BMX
Yep better gears in the 08 engine. I'm going to use the technigas pipe -just need to get a new variator for it and get it all tuned in.
Do you know which variator you are going with?lowblueranger wrote:Yep better gears in the 08 engine. I'm going to use the technigas pipe -just need to get a new variator for it and get it all tuned in.
- lowblueranger
- BMX
I haven't decieded yet. I've really working on the honda -got the new michelin tires on the metro wheels-installed the v8 pipe. I took it out and gps's it 49.9 mph almost wide open. It was pretty windy too, I think it's not to shabby for stock gears, wind, and my 260+lb * on it
Next step have the new gears pressed on!
What a great day for a ride. When was the last.time we could ride in january while wearing shorts?
- lowblueranger
- BMX
WOw I can't remember when we could in january. It's too bad weather changes so quick around here!
Ragbrai is coming through CR so we are planning a group ride up there. I think it is Thursday.
LBR- your elite is going to be baller, putting my sa50 to shame when we ride.
